alyevich
Have an 81.
Still learning my way around the car, just got it in the fall and have very little experience.
Spring has come and I had the car out a few times, yesterday being the longest time this year, approx an hour driving or so. (Note: I had taken it on several 2 hour trips in the fall, and this problem did not occur)
When I returned home I had the car idling in the driveway, when a fuel leak apparently started, and ended relative shortly. It was a bit dark, but I pinpointed the general area of the leak (behind the front driver wheel). I turned the car off and grabbed a pan. I would guess that about 12-16 ounces leaked. It stopped dripping after a few minutes.
With better ligthing this morning, I found that the fuel leak came from the vapor canister. On the bottom of the cannister is an outlet, but there is currently no hose connected to it. I cannot find any disconnected hose nearby. It it apparent that the fuel came from this outlet at the bottom of the cannister, as there were still a couple drops of fuel around the area this morning.
Would there be any reason for the previous owner to simply disconnect or remove the hose that connects to the bottom of the canister????
Looking in the shop manual, it appears that the outlet should be for a return line to the tank.
Any advice anyone can provide would be much appreciated.
Thanks,
Al
Thanks,
Al
