VATS issue, 1991
Speedbird!
New member
Texas
1991 White (base)
History. Owned car two years with no resistor key (wires cut to key), starter relay by steering wheel removed. Car ran fine.
Then I get no crank and fuel injectors dead. Reinstalled starter relay with ground bypass (starter cranks car).
If I pump throttle vigorously car will run 1000-2000 RPM with backfires but barely then dies.
Module 1 CCM Code: C12 ...on board diagnostic no codes
Module 4 ECM Code: 46 ... VATS error
I attempted to install 30hz/50hz bypass at ECM (no effect at 4 different setting or multiple wire locations).
I reconnected resistor key to VATS (no change).
Where do I go from here?
