K
Kaos
I have read many of the previous post regarding vats, and intremitant no starts
what i am unsure of is if the vats will allow the car to crank or not.
I have an 86 that will start and not start at will. when it does not start the
car cranks but does not start, wait 5 min. the car fires right up. (with out fail..always starts after 5 + min) may start 4-5
times without fail then no start, wait 5 min fires right up, and runs perfect, no stalling, sputtering or any other issue. does not matter if the car is warm ,cold
or sat for a couple of days.
Have replaced the fuel-pump ,fuel pump relay have spark at the plugs and
good fuel pressure......should i try the vats bypass???
