topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
I have a camaro tpi system that I want to use I believe its a 86-87 unit and Im using a painless harness how would I go about tricking the vats system without having all the factory parts like a decoder box and so on on my wiring schematic I see a battery terminal which is probably for memory but then it has 2 ignition terminals is one of these terminals connected to the vats system and how will my engine react to 305 injectors in the 350 Im not looking for performance just better driveability with this in mind will the 305 injectors do a good job also since my painless harness could never come close to reaching the trunk where my computer is located would a vette weather pack computer be a better choice so it can be mounted under the hood like the 85 up ones and what kind of a mount do the newer vettes use for their computer and are there computers truly weather resistant or do they have something else that covers them and does the vettes computer use the same ecm plugs as a camaro's for the 86-say 89 years thanks
