Bill75
- Joined
- Jan 1, 2004
- Messages
- 698
- Location
- Somers CT
- Corvette
- 75 Coupe ZZ4, Brodix IK-180's, Headers,TK0-500
I've been tying to find the source of the clutch pedal vibration at higher rev's for a couple of weeks. I thought it was something with the Centerforce II clutch so today I pulled everything apart. After I pulled the tranny I was looking at the clutch fingers and I see the damn pilot bushing laying in there sideways!!! It had pulled out when I pulled the transmission!
This is a new Pilot from NAPA, when I installed it I put it in a freezer overnight and still had to tap it in with a hammer and a flat rod. Now it just falls out! The O.D. measures 1.085. The O.D. of a new needle bearing pilot I was chicken to use measures 1.095. So this thing has been turning somehow and ground off about .010 off the diameter. I can see the score marks around the outside and the back of the crank has some brass residue from the filings.
The I.D measures .590 and the input shaft on the transmission is about the same.
This is a new GM 350 crate motor with the GM bellhousing off my old 350. It just dropped right on the alignment pins but in retrospect I should have checked it for concentricity and parallelism, I just never thought it was necessary.
Could there be a problem with the bellhousing alignment that would cause this?? This happened in 500 miles or so of very soft driving.
Bill
Bill
