Could be wrong here, but didn't the 350 and 427 have a different hood?
Of course the hood could have been changed over the years anyway. so this wouldn't be the most conclusive check.
There's nothing in the VIN prior to 1972 that would indicate engine option. You need to do some forensics- is there a tank sticker?
That will make things a bit difficult. The only ways I know of to confirm the motor size would be to see a copy of the dealer sticker or buildsheet(one was often found on top of the fuel tank). The last 6 digits of the vin were stamped onto the engine id. So if you could get some photos of this you could track it down. If none of this info is available then i'm not sure it can be done.The car is missing motor trans and Tank
...didn't the 350 and 427 have a different hood?...
here ya go: https://service.gm.com/dealerworld/vincards/
Example a S1210LA = built in St Louis 12th month 10th day RPO-L36 (427) and it would be a 3 or 4 speed transmission. A LC would be the automatic.
The problem is the decoder states "Only basic designations shown." What that means is if the car was (by the wildest stretch of imagination" a RPO-L88, the decoder won't tell you.
Seller told me the motor and trans were taking out 15 years ago he was asking $6500 for the car i offered $4500. the car will need about $25K to $30 k of work if it was a big block car I would buy it now... but with out the motor and trans to Verify the correct engine code its just a plan 69 stingray VetteSo where is the engine, transmission and gas tank? Does he have the originals to put back in the car. Don't the trans and engine have the VIN stamped on them matching the engine and trans to the car?
That is not numbers matching and without that, will be unlikely to recoup the kind of money you are looking to put into it.but with out the motor and trans to Verify the correct engine code its just a plan 69 stingray Vette
...Fed required a partial VIN to be stamped on the block from 1/1/68 on...
