- Moderator
- #1
KANE
Moderator
- Joined
- Mar 2, 2002
- Messages
- 3,244
- Location
- KY
- Corvette
- Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Here is the question-
What would cause a voltage drop of 3 volts ONLY under WOT (Wide Open Throttle)?
This is the set-up on my '78-
91 TPI with painless harness (MAP equipped speed/density system, reads as a 91 F-body on a TECH 1)
91 Corvette 105 amp alternator (swapped pulleys and soldered in new connector)
4 gauge charge wire from alternator to starter (yes-its HUGE!!)
LT4 injectors, super coil, 8.8mm wires
This is a MAP car... no ESC like MAF cars
New cap, rotor and coil.
I checked for an open or gounding out curcuit. None. No shorts. I checked the battery at an idle- 13.7 volts and the Alternator at idle is the same. The voltage does increase as it should under light throttle over 1k rpm.
The voltage drop seems to be directly related to how long I keep it under WOT. For a quick downshift- its okay. The drop lasts for a second. But if I hold it in WOT... well, it drops steadily below 11 volts and then the TPI hesitates due to insufficient current to run it. There is a direct relationship with voltage drop and engine speed ONLY under WOT.
My thought is the CONTROL MODULE for the HEI. It seems to me that when its under load that the module can't keep up.
Any ideas?
Any ideas?
