Grizzly
- Joined
- Aug 23, 2002
- Messages
- 430
- Location
- Centerville, PA, USA
- Corvette
- 1967 Marlboro Maroon Coupe, 1992 White Convertible
Had an experience last night with my 67. The wire that bypasses the resistor in the ignition system decided to short out. Lots of smoke. Burned all the insulation off between the coil and the wiring harness. Scared the hell out of me.
Later at a post mortum I noticed a black mark on the top ignition shielding. It had rubbed through the wire and shorted it out. Whoever put the new wiring harness in didn't dress it out in such a way the the cover wouldn't rub it. That line is not fused I guess because it is only used to start.
Take a minute to check yours out, It will save you some grief.
