86-ZZ3
I recently put my '86 back on the road and one of the problems that cropped up was the washer tank leaking. I don't know if it's the tank, the hose, or the gasket between
pump and tank because I can't get at the tank!
I have taken out the side panel (easy enough) and 2 bolts from the tank that provides access to, but there is a 3rd bolt that recessed way on the other side of the tank which is nearly impossible to get to (let alone see). Does this mean I have to remove the inner lower wheel well to take out the tank and see what the problem is?
