R
RubyDropTop
Can I insert the word "Zaino" where you are using the word "wax"? Is that a safe assumption?
So, let's use the word Zaino from now on as that is the system that you have chosen, and it contains no wax.
That said, are you asking if washing your car will remove the Zaino OR are you asking if the Zaino should be removed prior to washing? I want to be on the same page.
Zaino Car Wash will NOT remove the Zaino that you have applied, nor would you want to remove the Zaino that you have applied in order to wash. After washing, simply add as many layers of Zaino as you wish, given appropriate cure times.
Does that help?
Does that help?
