Les
New member
I have experienced water in my 73's fuel. I installed a new gasket on the filler neck, a new cap and removed the rubber surround around the filler head to clean out the drain hole that it has. No luck, same problem. I just bought the car,it was sitting around for quite a long time. It has a pretty new tank and there is not much fuel in the tank. I see the water in the glass filter which I changed out. Any help would be appreciated! Thanksn
