V
vettin1
If the water pump gasket is leaking does that mean the water pump is shot???
Thanks guys!
Thanks guys!
vettin1 said:If the water pump gasket is leaking does that mean the water pump is shot???
Thanks guys!
vettin1 said:Thanks everyone!
Funds are tight so I was just gonna replace gasket. I can tell because I can actually see where it's spurting out. Also there seems to be some pressure in the coolant lines...logical assumption was that the pump was still spinning just not able to create the necessary pressure. I agree, I'll replace anyway.
