jackfit
I just finished dash cluster restoration and installed new dash harness. Pluged in all conections and turned on key. Water temp gauge did a 360 . Turned off key. Took out dash and took photo of guage , I marked tabs when cleaning cluster . Attached new plug on harness the only way it would go on. Is this the right way for conectors to be set up (see photo) could the new harness be wired wrong ( pink and green ) wires? Is the gauge cooked, from the wrong set up. It worked before the rewire.;help Which terminal gets the green sending unit wire?
Thanks for help,
Thanks for help,
