Water Wetter
mad47
Covington, Louisiana
1996 CE LT4
Can anyone give me some feedback on their actual experience with this product. Still running the factory T-stat and would like to reduce engine heat in around town driving.
I Use It
But I can't say that by itself it will make all that much difference. I started to use it along with a different fan, stat etc. I think I've read somewhere in here that some of our members have done that alone without other changes at the same time allowing them to decide if it made a differenece. Try doing a search.
I use it. It works.
Does it work? I cannot give a conclusive answer to that question. But I like "Water Wetter" and have been using it in all of my cars for many years now.
For more of this report, visit this performance site: M3 Tech. ;)
_ken :w
I tried it...
...several years ago and it did lower my temps about 15-20 degrees during summer driving.
However, my run-hot problem did not disappear until I replaced the clutch fan with a flex fan, and we had done EVERYTHING else, prior to the flex fan.
(new engine, shroud, radiator, hoses, belts, t-stat, water pump, clutch fans replaced yearly, tune up...flex fan fixed my problem)
Heidi
I also have to agree, if you are running hotter than normal temps at any speeds / driving conditions, water wetter will only be a band-aid and can not be considered a cure.
