vetahlk
1. Remove the hatch supports from cargo area and support with a board (I used a 1x2)
2. Remove the rear deck trim (3pcs)
3. Remove old weather strip
4. Clean all old goo, adhesive, and dirt(this took the most time and I used various solvents lacquer thinner and a product called goo be gone worked the best, just be careful not to damage the paint)
5. While you are doing the above let the new weather strip get nice and warm in the sun(this will aid in the softening of the strip for installation)
6. Install the new strip (I found it best to start at a corner and run it along the top of the header to the opposite corner and then around the rear of the hatch)
7. Reinstall the deck trim and hatch supports( the deck trim holds the weather strip in place and I'm told no adhesive is needed on this piece. I didn't uses any adhesive and the weather strip is firmly in place)
8. Clean and remove all finger prints from car!
Good Luck, it really isn't that hard! Let me know how it goes.
John
John
