mytoy
I am getting ready to replace all the weatherstripping on my 78 , I have heard that Corvette Rubber has very good ones , has anyone used these and if so what was the outcome thank you mytoy
Wipe the weatherstrips down first with alcohol to remove the mold release compound, or you won't get good adhesion with the glue.
Really? I'm having a hard time with this one....... wouldn't that dry the weather stripping out? I have to put my new weatherstripping all over my 81 since I painted it. I did use that remover - you are right its great. And I have the adhesive.... how much adhesive do you use? Just little tabs? For the door..... do you have to sit and hold it in place? Any pragmatic advice? I know I probably only have one shot at this. On my camaros the weather stripping is held in my little clips that fit into the door but it doesn't seem to be so on the 81 so I'm nervous!
... how much adhesive do you use?...
Depends on the piece of weatherstripping, but, I used a 1/8" - 3/16" bead. Easy does it.
...My other question comes to the mating of the door weatherstrip to the pillar post. Even if I stretch the heck out of it...it looks as though there is going to be a 1/4 to 1/2 overlap. What do you do with that?...
...even if I stretch like crazy they aren't really lining up...
Check the AIM. It's possible the overlap crush is correct.
Seems to me the fit of the new should be closer than what you are running in to. Are you sure you have the correct weatherstrips?
Whats the AIM?
