P
Pa Goose
About 2 weeks ago my left front low beam stopped working and later that day I noticed the turnsignals didn't blink. I got a new head light and since all lights came on when I turned on the signal seft or right, I also got a new turn signal flasher. This did not solve the problem.
Today I noticed all of the gauges were way below normal and volt meter indicated 13 volts almost 2 volts below normal. Now this is where it really gets weird! I turn on the parking lights and the voltmeter goes back to normal almost 15 volts and all of the gauges go back to their correct readings. If I turn off the lights after a short time the gauges start going back down again. :confused
What do you think?? Voltage regulator? Lost a ground? Should I take it to the shop?? Any ideas???
John
John
