Wet sanding?
  • Thread starter Thread starter 87blackroxi
8
87blackroxi
I have a couple of deep scratches in the hood and rear quarter. I talked to my uncle who has a 76' and he said to wet sand the gashes down and then apply some touch-up paint. Has anyone done this? I am almost afraid to do it just in case it messes the paint even worse
will this work on fiberglass? and if so what grit should I use?
thanks,
shane
When I bought my 91, it had some bad water spots in the paint. I wet sanded it with 1500, then 2000 grit. Then I buffed it with buffing compound (3M fine), then buffed with cleaner wax. That gets most of the fine scratches out. I used to detail cars way back when, so I've done it before.
If you don't know how to do it, wet sanding can be a gamble. I honestly don't know about sanding it down and then applying paint. To get the scratches out, it will have to buffed alot, I'd be careful buffing fresh paint.
There is really no point to sanding the scratch prior to touching up. What is really critical is to get the scratch cleaned out so the new paint is sticking to paint and not paint chips or dirt.
Apply a small amount of piant at a time - do not use the brush supplied in the bottle! I have used anything from toothpicks, to torn paper match sticks, the idea is to let the paint "flow" into the repair so it fills all the crevises and gets a good hold. It should take more than one pass with each allowed to dry fully between applications. I don't usually put any clear over it but some of my cohorts swear it's necessary.
Do three or four passes until the repair is built over the top of the factory paint. Then wet sand the raised repair down to the original paint's level. You'll have a hard time finding it after that. The less paint you apply with each pass and therefor, the more passes you make. the better the repair will end up looking. Like Slapsht said, 1500, and then 2000 grit, of course tape off a small area around it so you don't end up having to buff out stray scratched from the paper.
You really can't hurt anything unless you really bear down on the paper or sand through an edge. It may take a little while to get all the sanding marks out but they won't be deep and you'll do fine with some Meguiar's or 3M over the counter polish, be diligent and patient. If all else fails a detailer can wipe the 2000 grit marks off in a matter of seconds - and I never would have charged for something like that but it'll be super cheap if they do, less than $5 I'm sure.
Unfortunately, if you are like me, you'll end up having to clay bar, buff, glaze, and wax the entire car because you can't stand the very slight difference the polishing makes around the repair! You can remove the tape while you're buffing the small area by hand and feather the "polished effect" out. I've done that but then I ended up doing it all anyway because I felt like I cheated. Ya, I'm a little anal...
It is a deep gash. I don't want miracles but want it less visible. I keep telling myself, it is 18 year old paint so there isn't a whole lot to do with it. But i may try the above methods and see what happens. I plan on getting it painted towards the end of the year.
In case you do attempt the wetsanding, (which I've just done on a minor hood repair) make sure you let the paper soak for 15 minutes and use a sanding block. Something that is soft yet will hold it's shape. I used the backside of one of those yellow/black tire dressing applicators and it worked great.
The key is in the buffing. A power buffer with the right foam pad brought my little repair to a very glossy mirrorlike finish. Also give the paint time to cure before buffing. I waited a week.
Good Luck,
Len:w
