FactoryC3
I noted this just after getting my '81 and cannot figure it out. Is it a flame supressor?? Or what? :confused
It is a dual air cleaner:
1981 Corvette Dual Air Cleaner Assembly | eBay
I have never seen one of those....It is a dual air cleaner:
Thanks much...
How do you clean it...if you do?
FWIR, the inner one is filled with charcoal.
Most owners pitch them for a K&N; however, I would not throw it away as most 81s are missing it.
Thanks much...
If it's inside the main filter why would it be dirty?
Are you saying that the inner filter, that is attached with blue sealant in the picture, is factory installed?
Some owners claim starting problems vanished when they replaced both filters with a K&N. After a decades of use, that makes sense also. All owners claim more power after replacing them. Amazing, how some claim to be able to feel a couple of WHP.
As the above came from the internet and we all know the internet. If anyone owns a 1981 Corvette Service Manual, I'd be interested in learning what it documents.
LLC5
As I've never seen one, read or heard of one until Factory C3 posted which made me curious. So after a fruitless search through my library; I started searching. All I found was a couple of posts at a few different forums.
The inner filter was factory installed and one year only, 1981. The most viable claim was it's purpose was some kind of emissions component. Other reasons were backfire baffles, flow straighteners etc. Having owned a boat with a V8 the flame arrestor was nonsense and straightening flow before a 90° turn would lack any sense.
As most original owners pitched them for an aftermarket filter; they are only found on original low mileage 1981 Corvettes. Due to its function, the low mileage makes sense.
If it was factory installed (the more I look at the picture, the more it does look factory installed even with the blue sealant) then it probably is an evaporative emissions device required by CARB.
Some people also believe getting rid of the computer controls gives the car more power, but we all know some people never have their buttometer calibrated.
there's no mention of this filter in the service manual. It never refers to filters, only the filter or element.
There is definitely a double step on mine with a nice flat spot for a small filter of some type.The picture at the Ebay link shows a double step, the filter sits where the rust (so sad) is and the "extra" is higher. Do the pictures in the manual show the same steps?
Unfortunately, manuals are for fixing, they do not communicate design intent.
Just for the looking and info, here is a link for a new assembly...78 79 80 80 81 Corvette GM Air Cleaner Assembly PT 25040289 | eBay
