Hib Halverson
6 quarts of Valvoline straight 30w and a can of GM EOS.
You want to be very careful with GM Engine Oil Supplement (EOS). As it was designed mainly as a break-in supplment, it is not recommended for regular use. One reason is it has a high percentage of calcium in it to mitigate wear in grand new engines. In regular use that calicum can form deposits on the piston tops and combustion chamber walls which actually create more problems than they solve.
What I'd do is determine the concentration of ZDDP in the Valvoline you use. If it's more than 800 PPM and your engine is stock or near stock, you'll ok without any changes. If it's 1000 PPM or better you're ok with most aftermarket flat tappet camshafts.
Keep in mind that, when it comes to pour-in supplements or additives containing ZDDP or other chemicals, the idea that "if some is good, more is better" is completely erroneous.
For additional information on ZDDP and engine oils for Corvettes see an article here on the CAC at: Engine Oil Deep Dive - CAC's Comprehensive Look at Engine Oil and Flat-Tappet Camshaft Durability
