brandywine
I use Red Line 10W30. I change the filter every 3k miles and the oil about every 6-7k miles. I don't let the car sit over the winter without starting it every couple of weeks at least.
brandywine said:I use Red Line 10W30. I change the filter every 3k miles and the oil about every 6-7k miles. I don't let the car sit over the winter without starting it every couple of weeks at least.
Your 92 came factory filled with Mobil 1 and it needs it to keep oil temps in check since there isnt any oil cooler. Change your oil by the oil life monitor or once every year.Grizzly said:I'm not offended at all by a differing opinion, I'd like to settle this in my own mind. I would appreciate additional comments from Vettehead Mikey. He obviously has more real experience than the rest of us, but I wonder if requirements of aircraft maintence are comparable to auto maintence. Hopefully they are a great deal stricter.
On the other hand if you are like me the oil in my collector cars seldom even gets that dark because I change oil by time rather than mileage.
Any more details Mikey?
bill81vette said:I use Castrol GTX 10w-30 in mine
redvett said:Your 92 came factory filled with Mobil 1 and it needs it to keep oil temps in check since there isnt any oil cooler.
JohnZ said:Unless you take it out and drive it at least ten miles in the winter so the oil gets to full operating temperature, you're better off not to start it at all; otherwise all the cold-start rich mixture combustion by-products and blow-by contaminants combine with the condensation in the pan and make the oil more acidic every time you start it. That junk won't boil off unless the oil (not just the coolant) gets over 200*F. Just let it sit- won't bother it at all - none of the seals will "dry out" during winter storage - that's an old wives' tale.
I second THAT!!!!!!!!!!!!!!!!!!!!!ps.I use Castrol SynTec in my LS6 in my Haul'n Truck!!
I agree with the zinc and phosphorus part. Basically, when looking at an oil (I prefer full synth), I choose the oil with the LEAST number of certs (ILSAC, SAE, etc). More certifications means less phosphorus.I am a little late to this rodeo but the only thing that i can add to this is that for flat tappet engines Like ours we need Zinc and Phosphorus. the new oils do not have enough zddp to protect the cams from wear.
For example
Castrol sytech offers a special formula with higher levels of ZDDP and is labeled (Classic Car Formula).
Do you homework before you add any oil dino or syntetic for that matter
I am surprised that the ZDDP thing wasnt mentioned until the 3rd page.
Junkie - I've been told that it's better to break in a rebuilt engine with regular oil, a little heavier than one would use normally, for a couple of hours and then switch to the synthetic 5W30 (or whatever oil one uses regularly).
Do you have an opinion on this?
