Vettehead Mikey
When we have a runability (sp?) issue with a vehicle under warranty we are sometimes required to call our tech line. The first question they will ask if the vehicle is an 87 octane engine is: what brand of fuel is the customer using (preferably Top Tier and at a high volume dealer) AND what octane fuel. If the customer is using 92 octane in an 87 octane engine, their response is to get the customer off the higher octane fuel immediately because of carbon build up issues that affect valve coking and injector contamination. Apparently the chemicals used to get the octane rating higher promote faster carbon build up. 87 octane fueled vehicle still have carbon build up issues, but at a slower rate.
This flies in the face of the conventional wisdom that more additives is better and the assumption that high octane gas- the so-called 'premium' has more additives that 'regular'. In particular, the 'Top Tier' brands promote themselves as having more and better additives than non-member brands, so the recommendations you're getting from your tech line are kinda contradictory.
I'm half tempted to call BS on this one, but would be interested in hearing more.
