Hib Halverson
Pre-ignition and detonation are, indeed, different anomalies of combustion in a spark-ignition IC engine but they can happen alone or together.
For example, pre-ignition is caused by ignition sources other than spark plugs such as glowing carbon deposits, glowing spark plug side electrodes, glowing shards or splinters of failing head gaskets, even glowing parts of combustion chamber walls is the surface is rough or has casting "flash".
One reason its advisable to put colder heat range plugs in engines which see severe duty cycles is avoidance of pre-ignition caused by a spark plug which cannot shed heat to the surrounding head material fast enough and runs hot enough to ignite the air-fuel mix without a spark.
This pre-igntion, depending on when it happens can also cause the engine to detonate if the pressure waves generated by the two flame fronts occur close enough together in time that they collide.
Detonation is caused by the flame front expanding away from the spark plug raising the pressure of end gases at remote areas of the chamber to auto ignite. The pressure waves emitted by both the normal flame front and the autoignition flame front run into each other. Detonation, when it occurs, causes combustion temperatures to skyrocket and, if heavy detonation continues unabated, it can raise the temperature of carbon deposits or spark plug electrodes such that they cause pre-ignition.
Needless to say an engine which is both detonating and pre-igniting will have very limited reliability/durability.
The characteristic sound of detonation--that 5000-6000-Hz "knocking" sound:bang-- is caused by pressure waves emitted by the colliding flame fronts causing the walls of the combustion chamber to vibrate.
