Vette/Berlina-coupe said:
BerlinaBob here: JohnnyZ my friend, --you've either got Exxon/ShellOil-stock, or are a Charter-member of FlatEarth-society-Ltd. Prove it to yourself if you want to be stuborn about it, --simply poor your beloved fossil-oil into an iron/frying-pan, turn-on the gas-burner to "full", timing the point at which it starts to fill your kitchen with smoke (the same test with Mobile-1 will reveal an astounding difference; -that will have you removing that crude-stuff form your fine steed pronto!)...:nono
No, I'm not a member of the Flat Earth Society, and Mobil isn't the only refiner producing synthetic lubricants, nor is any part of an engine that sees oil anywhere near the temperature of a hot frying pan - looks like you're the one who got sucked in by Mobil and Castrol.
I've been building race engines (including blown fuel Hemis) since you were two years old, spent 37 years in Engineering inside the OEM industry with GM and Chrysler, have 7700 hours as a pilot and know more than a little about what piston aircraft engines look like at 1500-hour TBO, and stick by what I said earlier. Forget the marketing hype, the stupid frying pan ads, and the slick containers - having dealt with high-performance, race, OEM, and aircraft engine innards since I was 16, I go with results, not Madison Avenue marketing wizards; engines care about fresh, clean oil that meets stringent API specs, and could care less whether it's dino or synthetic. If you haven't been there, you're just pontificating. The synthetic-vs.-dino oil marketing war has been going on for twenty years, and will likely continue long after both of us are gone. Synthetics cost twice as much to make as dino, and sell for four times the price - 'spose that has anything to do with the marketing effort? It just might.
Engine manufacturers know more about what their engines need for lubrication over extended warranty periods than the oil marketers do, and so far (after twenty years of solid real-world OEM research and oil company marketing hype) none of the high-volume manufacturers have seen fit to require synthetics (except for the "halo" performance cars where Mobil subsidizes the factory fill with marketing agreements). My last plant (check my profile) only made ten "torque-monster" engines a day, and I bought Mobil 1 in 500-gallon tote tanks for little more than the cost of dino oil - try that at your Mobil station.
Fresh and clean is all that matters - twenty years of marketing hype hasn't made a dent in that yet.
