C
crebo
I finally got my car back. I now have the 402BB installed. I have a 270 cam. A set of hiedman headers, mallory dist. 427 heads? I'm gonna check the casting #'s to be sure. Exhaust straight back. My block casting is 3902406. It's a four bolt main. I have a small overheating problem. I think I'll switch over to a big block fan clutch. I have a 165 thermostat....so that's a small problem we need to fix. I've also sheared a A/C bolt.
The main issue is we talked (mechanic & I) talked about 800cfm carb. We only put carb in writing not the size or the nomenclature. Anyway after researching I have what seems to be a modified Holley 650. #'s I can find are L7054. I also found this # on the base plate 12R 5395B (didn't research it). The book says this is a double pumper. I has been modified to be a single. I already have a 750 Edlebrock electric roughly 1 1/2 yrs old. The mechanic is swearing that the Holley 650 carb is bigger than the numbers list. Saying that it is bigger than my Edelbrock.
I really don't know what to do. Should I just put my Edelbrock back on. Should I keep what I have or have him convert it back to a double pumper. I'm also thinking if it was a double at one time why would he change it. Surely not for a BB. Maybe something is wrong with it anyway. :confused
If anyone has any info to offer it will be appreciated. Let me know if I'v missed something on the carb.
Actually I'm pretty happy with the car until now. Carb issues. If he cut these corners....What else? I've had a good mechanic friend check over the and everything else seems to be up to par.
Ashman
Ashman
