S
Skant
Alright... my tax return was surprising this year. I'm getting $3000 refunded! And I plan to put it straight into the 'vette (a stock 1996 LT4 CE)
I've studied these forums quite a lot, and I've got some ideas on the best ways to utilize this money. But I'd like to ask what you guys think.
First off, the thing that alters my plans a bit is that I noticed this morning that there is a nail in my left rear tire (!!) and a cut on the outside corner. Wheel Works reports that the tire is not repairable and will have to be replaced. I have been planning to eventually upgrade to Goodyear F1 GS-D3 tires. The car currently has Goodyear HP Ultra Plus tires on it that are about a year old (came from the dealer this way).
So the first decision is... do I replace just the rear tires or all four? The fronts are still good. But I kinda wonder about having fresh meats of a higher quality on the rear and older economy tires on the front. I guess that would tend to produce understeer which is maybe not sooo bad. I understand vettes tend to wear out the rears at twice the rate of the fronts anyway, so I just aughta get used to having newer rears than fronts half the time anyway.
If I did replace all four, could I sell the half used up fronts? Hmmm.
Next are 'go faster' options. The tires will chew up either about $500 or $1000 depending if I replace all four or just the rears. So that leaves $2500 or $2000 left.
I'm talking to Northstar Automotive Technology about doing the upgrades. Don't have quotes for most of the possibilities yet. But I'm thinking that bolt-ons and gears are the generally more bang for buck items.
I had planned to do 4.10 gears, Corsa exhaust, SLP triple intake, coolant bypass, and lowering the front end. I suspect all that can be done for about $2500. Hmm... or maybe not quite.. probably have to drop something out of that list. My estimate based on my research is that this combo would be good for another 20-25 horses plus a 20% advantage in gearing.
Northstar recommended (without knowing my actual price cap) in this order: Borla Exhaust, Breathless Airbox (not the veriram, but a better type?), larger throttle body, and shorty headers. They claim that this set would 'conservatively' add 35-50hp.
Thoughts? While they didn't seem to especially recommend changing gears, I'm pretty sure that's where the biggest difference will be felt. So I'm pretty sure the 4.10's are item #1.
If the exhaust is second... well, Northstar is a Borla outlet... so of course they recommend Borla. Any thoughts on Corsa versus Borla? I've heard a Borla briefly. Haven't heard a Corsa yet, but I like the idea of what Corsa is supposed to provide. I'm guessing that both systems are the same on horsepower gains, so it's a matter of whether I want subsonic rumble (Borla) or a higher pitched roar (Corsa)?
I imagine either airbox would do well. The breathless one requires cutting the shroud and it feeds from the bottom of the car. Dunno if this really make much advantage over the triple SLP intake. The posts on this forum sound like a tossup between the two.
Larger throttle body and shorty headers... digging through the forums, it sounds uncertain whether these items will actually add any performance over stock. I've seen a lot of claims that the stock LT4 headers are very good and only non-smog legal (I live in California!) long tubes would outperform them. And I've often heard that larger throttle bodies will lose power, not gain... unless internal engine work has been done (ie. stroker, etc). Plus I'm not sure if I want to lose my 'Grand Sport' plaque on the throttlebody.
Okay... so given everything I know now... this is the list I'm leaning towards... in order... I'll probably run out of the $3000 before I reach the last items...
2 Rear Good Year F1 GS-D3 Tires
4.10 Gears
Corsa exhaust (Maaaaybe Borla)
Breathless airbox
coolant bypass
Lower front end 1-2"
Thoughts? Advice? Something I'm missing? Thanks in advance!
4.10 Gears
Breathless airbox
coolant bypass
