Steve & his C4
Hi everyone!
I'm new here. Hoping some of you could pass along some suggestions to me. I recently bought a 85 with a bad engine. Other than the engine, the car is in great shape. (Brand new interior too!)
Here's my predicament. There's obviously a bad piston in the original existing engine. The car is completely stock. Would it be best to tear down and rebuild what I have? Do I make it a 383? Do I abandone the tune port and install a carbureted,fresh 406 I have? (I've researched what I'd have to do to install the tune port) OR, do I pick up a wrecked Vette with a LS engine and trans and attempt a transplant? Not even sure if that last one would be an option.
Any input from you folks that have, I'm no doubt had more Corvette experience, would be greatly appreciated. Thank you in advance!
I think any one of those scenarios is an option. I'm sure all have been done in the past. I guess it all depends on which direction YOU want to go. I'd think that the ease of doing them is also the order which you listed them. Using the TPI, I believe, would be the easiest path. When you go to the carb version I think you have a lot of issues with the gauges and other computer things. Going to the LS, brings it's own set of issues. Hopefully, someone with actual experience doing these options will chime in here soon to shed some light into the matter.
