LanceB
It is a 77 L-82 3 speed auto. I need to replace filter and gasket. All I see under it is Hydra-matic written on the oil pan can't find anything else yet to identify it....leaking like crazy.
Found at Autozone, tight fit. Looks like I overfilled fluid tho. It was showing way low, then poured 1/2 quart in, now way over the circle on the dipstick. can't believe no drainplug. Guess I will loosen bolts and drain some out.
