80convertible
- Joined
- Jan 26, 2001
- Messages
- 416
- Location
- Asheville, NC
- Corvette
- 1973 converted to 1980 custom convertible
Last year by car started running rough and I notice that my tach needle bounces a little...not much but not a smooth idle. I had not done anything to the engine, so I'm not sure what is causing this. My spark plugs, wires, distributor cap and rotor, air filter all have less than 3,000 miles on them. I know its not the tach filter because I've never had a tach filter on the car in the 5 years of ownership. This problem just started last fall. I belive my distributor is old. Could the distributor be failing and causing some kind of ignition problem which would cause the tach needle to fluctuate? Could this be related to a timing issue? Any suggestions are greatly appreciated.
