Question: Wheel Alignment
  • Thread starter Thread starter dogfish246
D
dogfish246
I am getting a wheel alignment for my 96 becasue my tires just got destroyed on the outter edge!
What should the place Im taking it to, align the tires to? I use it as an every day driver and it is a Z51 (if that matters). They are using a lazer alignment system.
I am going to let them do their job, but I want to compare their alignment numbers with someone with experience.
Thanks!:cool
If it's a modern computerized machine specs for most vehicles are stored on the hard drive (as long as it's kept updated) and guides the tech thru the alignment process.
Thanks!:cool
I've used -0.5° camber on front and -0.8° camber on rear for over 3 years and I get even tire wear. Front toe in is 1/16" but I forget what the rear is.
