Todbo
Recently had my Chevy Dealer to replaced the 21 year old original Goodyear EMT tires (with 21,000 mile use) on my 2000 C5 and in getting the car back found all four wheels had the "stick-on" balance weights to the inside circumstance surface of the wheel - and that three of the four wheels had a 1.0 -1.5" length x 1/2 - 5/8" width damage area to the outer surface area of the rim (these are the optional 5 spoke aluminum wheels for the C5). Dealer thinks these damage areas are the areas underneath the original weights applied to the outer rim surface area of the wheel at the factory.
Does anyone know if any of the C5s left the factory with wheel balance weights attached on the outer surface side of the wheels? - if these rims can be repaired and if so by whom/where? - and if the stick-on balance weights are going to damage the inside circumstance surface of the wheel and should be replaced with weights on the inside area of the rim?
My 1994 C4 Vette which originally came with EMTs (as well as a spare and jack!) has had the tires replaced and neither the original set of tires or the replacements used neither outside rim weights or the stick-on weights.
Many thanks.
Many thanks.
