L
Lucky
I just had new tires put on and was wondering if I need to have the the lugs re-torqued after a certain amount of miles?
Ken said:Anytime you install aluminum wheels, or after a wheel has been off and then re-installed, you should recheck the torque level between 50 and 100 miles of operation, and retighten if necessary to the recommended torque using the proper sequence. It's even recommended that torque checks be made as part of a vehicle's scheduled maintenance program, or at approximately 10,000 mile intervals.![]()
