When making a sharp turn traction control warning service vehicle soon
  • Thread starter Thread starter Moseefuss
M
Moseefuss
I read some about this problem. Purchased a service manual to trouble shoot my C5. I'm unable to find the section on traction control system. I don't want to take it to the Dreaded Dealer. Any suggestions. Thanks very much.
No problem, Mo... happens to all of us.
Here we go...
:wJane Ann
DONE!
EDIT: I also got rid of your duplicate thread since this one is now in the best forum for replies. JA
Thanks Jane Ann
I can live with it but like things to be perfect
or close to it as possible. I was hopping it wasn't a sign of something worse fixn to happen.
Thanks,
Mo :thumb
Here we go...
:wJane Ann
DONE!
Is the Service Manual you purchased a three-volume, factory service manual or an aftermarket "service manual" such as Chilton or Haynes?
Thanks,
Mo :thumb
If I can help by eliminating duplicates and getting your thread where it will receive the most attention, then I've done what I'm s'posed to.
Again - welcome to our little forum and good luck with your fix!
:wJane Ann
The swps is about $65.00 at GMPartshouse.com. It takes about 2.5-3 hrs to replace. Just had to replace mine on my 04. Unless you are comfortable working around the airbag, it is a job for the pros.
It is not that hard, the hardest part is removing the steering column. Just remember not to turn the steering wheel after removal so you do not unwind or over wind the clock spring for the air bag system.
