Crispyc21
Where are the grounding points for these codes? I have the printout of where all 13 grounding points are but because I have limited time to work on my car I'm hoping I can pin point the ones I need to check.
I received these codes one before about a month or two ago. They go away for that long when I clear them.
C1725 RR Shock Absorber Solenoid (Short to Voltage) -This one might be a bad shock.
B0432 Rear Defogger Relay Circuit
B0332 Outside Air Temp Sensor Short to GND
B0337 Inside Air Temp Sensor Short to GND
B0361 Left Actuator Feedback Short to GND
B0365 Right Actuator Feedback Short to GND
