Help! Where does this part go?
J
Juskie77
In the attached photo is a bracket, that I can't find in the assembly manual. I'm 90% sure it was to support the dash, but I scoured my photos of the dis-assembly and can't find where. Anyone know? The bent end is threaded and the straight end has a slot at the end.
Bonus: Second picture, same problem. I think these two brackets went with the ductwork somewhere. Any help here?
Thanks for your assistance!
Did you replace your heater core? It looks like a support for the core and the clamp for inlet/outlet pipes located inside the heater/AC case.
I think that is where it goes! Thanks for the tip. Any thoughts on the other rod/bracket? It is for the dash right?
Tim
Rod from the bottom of the radiator support to the reinforcement bar under the nose. AIM shows it.
:thumb
Wow! I was way off on the rod. Thanks for pointing me in the right direction both of you! I was able to find the picture of the rod on the nose and found it in my AIM when i was looking for the right thing :)
