Aha I see, we have the same inspection. Overhere in Holland if the car is under 30 years it's ones a year and above ones every two years. Not a big problem as qualified garagepersonel can check the car and they can get a inspector to recheck if you're not so "lucky". But even a recheck isn't a problem as the car should be good to start with! I know the garagepersonel for several years so they think with me and not against me. (For example handbrake with a automatic is never used anyway, so they set it to tight for the check and back again if there is no recheck, etc etc)
I hope they find the rattle! And good luck working hard to affort your power and PC
Greetings Peter
Just to close this out: Just got the car back. Another 2 years of smiles..
He replaced the Master Brake Cylinder, new brake pads out back, repaired the front calipers (they were leaking), swapping tires front to back, replaced oil and filter and adjusted the darn handbrake (The German Inspection guys are crazy on those, if they don't work, they will fail the car). So, car passed flying colors, as usual. But... (You knew there was a but coming didn't you?
He detailed what we should tackle in the next 2 years:
- the bushings front and back are worn, hence why the car does a bit of a shimmy dance going over 80mph, so he suggested full repair kit for both axles
- the filler neck/tank is sweating when the tank is full, hence the gas smell once in a blue moon
- and we found the reason of the rattle....
ad
Peter was right in his PM to me.. Detonation.. Appears #5 and #6 have oil in them and detonate early/misfire. Which can be 2 things but both would best be done with a rebuild/re bushing/over bore of cylinders (read: Lots of Euros)..
I'll wait on that until we do a full frame off. Car is running ok, except for under load and warm..
ok, so, car is back with me, and was driving fine coming home.
Now, let's use our C3 forum a bit..
Stefan
