Where to find the RPO codes on my '84
elkabong
Chandler, AZ
1984 Red Coupe.
I have looked in the center console and both rear compartments but not sticker. Is there somewhere else to look that is readily accessable?
elkabong
I also heard that somethimes, the RPO / build sheet is on the engine compartment firewall.
I'll check the firewall. Seems kind of odd that GM would put codes on the top of the gas tank. Wouldn't you need to drop the tank to get to the codes? hmmmmmm
I guess I am lucky, my codes are still taped to the inside of compartment door behind the drivers seat . . .
They put 'em anywhere they want. You might also find one (a build sheet) up in one of the front frame rails. ;)
_ken :w
I've looked everywhere. Oh well, I'll wait to go get the stuff from the Corvette Museum.
Thanks.
On the 1964 Coupe I once owned, I did check on the top of the gas tank, and the sheet was loosely glued to the top of the tank. I suppose it is there for a more permanent record that would usually stay with the car, since it wouldn't get wet or rubbed off there, and would be available "if all else fails".
