hmcquade
I am going to have the OD rebuilt by my Mechanic we need the toosl to adjust the TV cable inside the OD. the Following was from David F instructions on how to rebuild the OD:
To adjust the TV cable on the valve body, install tool J-34671-1 into the TV cable bore on the side of the case and set the hook on the high step of the gauge. Place the cam stop on the valve body as close to the lever as possible and install the retaining bolt.
Next, set the hook on the lower step of the gauge. Place tool
J-34671-2 between the piston and solenoid bracket. Adjust the bolt on the TV lever until the lever just touches the tool.
Thanks,
Hugh
Thanks,
Hugh
