V
vmrod
I don't remember how many RPM's I lost, but I remember (this was 7 years ago) a squeal whenever the A/C compressor kicked on, and also my engine felt like 'something' was trying to stop it from turning. This problem persisted until I could actually see the A/C pulley turning slower than the belt and I could hear the squeal coming from that place.
I don't think you need to go to a corvette specialist for the problem. I bet an A/C shop would be your best bet. Ask if they can test to see if the compressor is binding up. (Alot of A/C shops are charging $25 for a A/C diagnostic. Not too bad.)
Just reassemble your car, but remove the A/C belt. You can at least drive your car then. Bring the belt with you to the auto shop.
There's one more test that you may be able to do yourself. What if you removed the A/C belt. Now, with the car running and the A/C turned on, see if you can spin the pulley yourself and how easy it is to turn. If it is excessively tight, then you can take the car in to the A/C shop for professional testing (I know, again).
