B
BlackRat
I am considering off set trailing arms in order to fit the biggest rim and tire combo possible on the back. Who is using these and what wheel\tire size and type are you running?
Also I had Bairs redo my bearings and rebuild everything. Now that I am thinking of the off set trailing arms do I have to worry about bearing setup again or is that separate from the T\A's and just a bolt on mod?
