- Moderator
- #21
- Joined
- Nov 9, 2000
- Messages
- 7,560
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69), 1981 Beige L81(10/20/80)
I've seen that happen before too. Have you checked the radiator for bubbles when this happens? If it's pushing air into the cooling system I'd think it might bubble in the overflow tank so you wouldn't have to risk removing the cap. When the electric fans are running all of that air flow would be going through the radiator. By all means replace the foam seals around the radiator be be sure that all cooling air passes through the core. Your water pump should be ok if it isn't leaking. I suppose that the blades on the impeller could corrode away enough to reduce water circulation. You would have to take off the rear cover to see that. Zip has a rebuilt kit if you would want to do it yourself. It isn't hard. All you need is a shop press.
Did you have the block bored when you rebuilt the engine? It could be that you are transferring more heat into the cooling system than you were with the thicker cylinder walls before boring.
Tom
Tom
