window motor
  • Thread starter Thread starter tunedportvette
T
tunedportvette
Has anyone changed the right side window motor on a 95 vette?
How hard is it?
It's not too bad.Takes about an hour.
Remove outer door panel,remove inner panel and have someone hold the glass as you disconnect the 3 nuts on the channel.Then I believe there's 2 bolts at the top and one on the bottom of the mechanism.Might mark the position before removing.Then just swap out the motor.and reverse to install.I don't have my FSM with me i'm going by memory. Maybe someone can help us if I've left anything out.
Good Luck
I replaced mine, all I can say is take your time, and mark all the bolts first!
