sriat
OK had the Vette painted couple of weeks ago. While they were doing it I had them replace the seals on the entire car. THEY WERE DUE. PS 84
So when I got it home the windows would not roll up. SO i assumed that the issue was the motors. I replaced them. I then broke the window ribbon that the motor pulls on. So I am replacing that on drivers side. Point being there must be too much pressure on the motors/ribbon. It looks like the seals on the back of the window is causing the problem. I lubed them thinking this would be a temporary solution. No go. Any adjustment that I am missing? I have checked for other binds this seems to be the one. If the door is open the windows work fine. Looking for solutions...
