Window Problems HELP!
sriat
Kansas
1984 Bright Red Coupe
OK had the Vette painted couple of weeks ago. While they were doing it I had them replace the seals on the entire car. THEY WERE DUE. PS 84
So when I got it home the windows would not roll up. SO i assumed that the issue was the motors. I replaced them. I then broke the window ribbon that the motor pulls on. So I am replacing that on drivers side. Point being there must be too much pressure on the motors/ribbon. It looks like the seals on the back of the window is causing the problem. I lubed them thinking this would be a temporary solution. No go. Any adjustment that I am missing? I have checked for other binds this seems to be the one. If the door is open the windows work fine. Looking for solutions...
Why are YOU messing with it, and spending more of your hard-earned bucks? Give them a call, describe the problem, and ask them to make it right.
