Note: This feature currently requires accessing the site using the built-in Safari browser.
I would have the Alignment done!! By your description I'd say it has some Torque Steer!! Can you get the same feeling cruzn about 65 and run over a expansion joint on a bridge??OK I have a question for y'all. I have installed a VaraRam air intake and a FAST intake manifold only on my C-5 (2001) MY rocket, since doing so I have noticed when I accelerate from 0 to 60 and beyond and at my shifting point at around 6000 rpm I get a twist and a wobble going from 1st to 2nd, and from 2nd to 3rd I don't much look at the speed I am going. Now, the car has I think the F1 suspension it is called, and it is really a beautiful riding car at any speed. I have ordered the Z06 Sway Bars, and the insulated 1/4" tunnel brace. Should I change the shocks also?:confused Scott
I would have the Alignment done!! By your description I'd say it has some Torque Steer!! Can you get the same feeling cruzn about 65 and run over a expansion joint on a bridge??![]()
Scott, does it feel like the rear is sliding to the side even though you are not breaking the rubber loose?
If so you might look at the shocks. My RR shock is softer than the LR and I have the same sort of strange feeling on hard shifts.
A soft shock very well could cause it!!The Z bars will make it more stable in the curves,but you won't notice anything except maybe slight more road vibration on the straits!!
How many miles are on the car??![]()
What a great topic to discuss- I noticed you did two major bolt on upgrades and that undoubtedly added some additional hp and torque! Great move and I dare say some of what you are experiencing is attributable to that! Corvette Junkie explained the soft shock and with 41k on your ride it wouldn't hurt to do a shock upgrade! Now I did not notice if you had the F45 suspension option or not but..if you do then I would not advise changing anything! If you have the base or Z51 consider the 2004 Z06 shocks as they add some additional handling but.. you will notice a stiffer ride.
Scott, I did a visual inspection on mine and noticed it leaking oil. I have the F45 adjustable suspension so I found a used set of F45 shocks to replace it with. Not the best solution but it was a LOT less expensive than the $400 bucks for one new shock. Besides I figure it will get me down the road until I'm ready to put the Bilstein sport shocks on.
Rain, bought 4 FE4 Z06 I think at a dealership some where on special for less than $250.!! PM him!!Wow, that's big bucks for one shock. Is it because of the Selective Real-Time Damping with the F45 suspension? Mine is the FE1 base suspension, and they have the FR Shock as C, and the RR Shock as E on the build sheet for my car. Does anyone know what that means other that a soft shock? I am going to change the sway bar to the Z06, and replace the tunnel support with a 1/4" insulated one. Mid America has Bilstein Z51 Gas Shock for $300 a set (4), and Corvette Garage has Bilstein Sport Shocks C-5 -Z06 for $350 a set (4).
