I happened to be looking for a leak while the engine was running, and noticed that my crank pulley doesn't seem to be perfectly even. Essentially, it wobbles up and down (not back-to-front) some small amount. It's tight, and I can't easlly tell if the harmonic balancer is ALSO wobbling. Is this a cause for concern? I know that the aftermarket underdrive pulley on my Subaru looks the same and it hasn't caused any issues in about 100k of use.
Unless the crank were bent, I can't see how the HB would not be on straight, unless it's no longer balanced right. I thought with the three bolts, the crank pulley was self-centering. No?
Comments are appreciated...
Thanks.
[RICHR]
Thanks.
[RICHR]
