autopat
Hey guys and gals, I've got a weird one for you. I have an 84 CFI, 4+3, I put a new ignition lock cylinder in it a month ago (just worn out), everything worked fine, had the clutch replaced last week, trans shop says they couldn't get the car out of reverse so they disabled the column interlock, replaced the clutch, now the car will not shut off. No it's not dieseling, it does not shut off when you turn the key off, everything stays lit up, just like it were driving down the road. If I turn the key off, hold the brake, and stall it by letting the clutch out, all the guages, and powered equipment, turns off just like it's supposed to when you turn off the key. Did they forget to reattach a ground cable? Is the interlock to blame? Haven't really had the time to dig into it, I did check the fan relay, the fan is not keeping it running. Any and all help will be appreciated.
Pat
Pat
