badnews_bill
New member
I have a 1989 corvette that will not start unless you use starting fluid, then it starts and runs fine. If shutdown and restart it won't start. I have replaced injectors, fuel filter, drained and replaced the gas with hitest, oil and filter and oil sending unit (was getting 10 psi now 40 psi) I have 41 psi of fuel pressure at the fuel rail. The injectors have 16.4 ohms cold and 17.5 ohms hot
Read more: http://www.justanswer.com/questions/16eyt-1989-corvette-grounded-pin-f#ixzz0NQbVSjPu
