Rodney Gold
- Joined
- Jul 28, 2003
- Messages
- 200
- Location
- South Africa
- Corvette
- 1986 White l98 coupe, 1995 LT1 coupe
all of a sardine I have a "woosh" when braking or holding the brake pedal down , and sometimes the pedal is easy and sometimes hard and high. Revs rise as well on braking indicating a vac leak.
Braking is all there and I have ruled out any vacuum leaks in hosing etc right to the brake booster - IE no vac leak elsewhere.
I have sucked on the booster hose and it seems the booster doesnt hold high vacuum and I think its boggered...It doesnt suck your tongue at the end of the hose , you can feel resistance but can continue sucking without increasing vacuum.
Braking effort much better when the car is cold , as soon as I drive it a few mins the braking effort rises a lot.
1) How would I know for certain its the booster (grommet and check valve seem 100%)
2) I'm in South Africa , so parts not that easy to get , what booster do i need to replace it with?
1980 Vette....
3) Should I get it repaired here by one of local brake shops? whats the chance they can fix it ok?
Ta for any responses
1980 Vette....
