youwish2bme
After following Vigman's series I got a lot accomplished today, needless to say I didn't get much done today via work, except once again visiting the Dodge service department. However a lot got done on the vette today.
Holes that someone drilled in the vert deck lid (hardtop mount location) got the black plugs removed, drilled holes to 1/2 inch and installed chrome trim.
Replaced drivers side parking lamp turn signals still didn't work but parking light says lite now.
Discovered that the switch bubba installed under the dash is for the back up lights (Hurst shifter).
Discovered my power antennae actually works (found this the same time as above) The sw has the toggle broken off it, new sw to be installed. Although the antennae is still going to be replaced w/ a 67 fixed mast though.
Replaced the gas tank overflow rubber, boy was the old one brittle. Still have to get nipple and hose so that if it does spill it will go somewhere besides on top of the gas tank.
Try to align the vert deck lid w/o success though, This has to be a two man job and I was short at least one man today. Oh well that will get done soon.
Turn signals now work it was just the flasher, removed the one from the hazards that worked somewhat (DIM AND FAST) installed it in place of turn signals and they now flash slow and bright.
Replaced the bolts that bubba had in the spark plug shielding w/ wingnuts...
Well that I have rambled on and on I think I'll take a drink...
Okay one last thing something is loose in the steering column still and I don't have the courage to pull the steering wheel quite yet... Dave..
